I think my only gripe about the Rackbrutes is that they didn't really incorporate 'airflow' through it and have seen a couple modifications that use the 'laws of physics' for some natural airflow.
-- jb61264
Which comes back around to why I keep insisting that the width is, as Arturia notes, 88 hp. Simply because it's possible to jam 89 hp worth of panel space into these is NOT a good reason for doing so. With 88 hp and its slider nuts, you can add a little bit of space across the panel by slipping each module a TINY bit, and then this should help with the internal heat issues.
I think I made this argument a couple of times, that Arturia states the width is 88 hp and there's a definite reason for it...this problem being exactly that.
