Thanks for the thoughtful reply @Sweelinck
The only important type of module that I don't see here is an active multiple (Buff Mult type): indispensable for pitch cvs or other signals requiring high precision.
The Disting Mk4 should be kept, it will always be useful even in a larger configuration. And for example in this setup: if you need a delay or a Bit crusher. It's a little 'comfort' module that is good to have in reserve. That's what made it so successful.
I keep thinking I will want a dedicated buffered multiple so I will plan to get one at some point. I could easily swap it with the 2HP S&H, because there is already a S&H and the Disting could be another S&H as needed.
I know I will want more utility modules and delays but I need to spend time with the actual hardware and really learning how to use it, to see what makes sense for me. The Disting could be very helpful to experiment. If I am always using the Disting for a certain purpose, I would eventually buy a dedicated module for it and then try using the Disting for something else to see where to go next. I feel like this will be a good strategy for slowly expanding my rack (and eventually into another/bigger case) without wasting money on "unnecessary" modules. Even if the Disting is not my favorite due to usability challenges, I think it will still offer a lot of value.
A controller, or a manual trigger, could also be recommended. This is the interest of the physical modular, beyond the tweaks, to be in direct contact with the physical dimension. See LS1lightstrip, Ears, TP8... while waiting for a Planar, or a Tetrapad for example.
Hmm, I'm glad you brought this up. I realized I want to trigger things like the sequencer resets without needing to hook up a MIDI controller.
I have a question about this. I have found there are often many ways to accomplish a task in modular. To reset sequencers, I could of course use a slow clock division to reset and re-sync everything periodically, but I will also want to do it manually. This module can be worked into my plan and seems perfect for this need, plus I get pressure sensitive CV control too: https://www.modulargrid.net/e/intellijel-fsr-1u
However, if I don't buy a dedicated controller/manual trigger right now, I believe in theory I could use an attenuverter to trigger the resets and other trigger inputs. The attenuverters are normalized to DC, meaning I can plug in the output and control the voltage directly with the knob. My questions is: if I were to plug an attenuverter into the sequencer resets, can I turn it from low to high to trigger them? My intuition is trigger inputs are triggered by the voltage going from below some threshold to above the threshold (maybe with hysteresis to prevent double triggers), so I don't need a dedicated trigger signal necessarily, I just need something I can make go from low to high voltage.
Do I have the right idea, or in practice is it better to use a dedicated trigger signal (a short pulse) to avoid strange behavior?
My advice would also be not to buy everything at once. Restrict yourself, at first, to the ones you are sure to want absolutely.
Good advice. I feel comfortable with my current plan, and I am open to the plan changing once I get started. So my next step is to figure out where to start. Every time I try to refine my plan, certain modules are included, so clearly they are a good place to start.
The main thing at this point is to decide what cables to buy and I have no idea yet. This is part of what I could never experience in software and I have no point of reference. I am thinking I should get a few "standard" cables (that stick straight out) of various lengths. It has been recommended I get cables with different shapes, I guess you would call it an "L" connection, like these: https://tendrilscables.com/ And I know I want some stackable cables. I guess I will get a mix of maybe 30-40(?) different kinds of cables and see how it goes, unless someone has some advice here?
