From the description on Instruō's website: "Each independent core is free running with rates configured from fastest to slowest arranged from top to bottom. Each frequency range was tuned by ear during development to give the optimum spread of control frequencies running in parallel. Being 100% analogue, the LFO’s will phase organically with the ability to ebb and flow together with their global frequency control."
-- jletra
Okay perhaps I explained it a bit wrong and you might be right about the above part description. My point however is that you don't have really 8 independent LFOs. Okay they might be "free running" but what is free running in this context?
To me, free running LFOs are the opposite of triggered LFOs. They start and you cannot reset/restart/trigger them.
Instruo's description to me sounds like they're all on a independent frequencies but you cannot change the ratio between them. So if one is 100Hz and the next 120Hz, if you go down one octave it'll be 50Hz and 60Hz.
Modular playlist on SoundCloud
