I kind of know what you mean about the black sequencer - it's a lot less immediate and demands a lot more effort than the metropolix
I've only played with a metropolis (not metropolix) once, a few years ago, and it was extremely intuitive to use on a basic level - ie I managed to get a sequence going with it in minutes, without the manual etc etc
I've had a black sequencer for a while and it takes a lot more effort to get into ie I still need to consult the manual - but I think that I'll persevere with mine - one thing you could try is creating a sequence on the metropolix and then recording it in the black sequencer - I do agree though it does seem a bit of a waste to just use as a midi->cv converter
you might want to look at cv.ocd, or the module version mutant brain if you decide you want a midi->cv module
