a matrix mixer - really handy for: getting more complex modulation from what you alreaddy have (mult 4 modulation sources, get 4 more complex ones out), feedback patching (mix output of xyz module back into input), send/returns (send outputs of modules into inputs of effects and then mix outputs of effects back into original signal - useful for effects modules that don't have dry/wet controls)
Is there a good in rack option for this, or is it better to go to a standalone mixer?
joranalogue compare 2 - great logic module...
I'll check it out!
I know what you mean about modules that already have xyz in them - but usually it's part of something else - taking useful functions out so they can be used on their own is a good practice - so you always have that functionality available, even when using the module for something else - Maths is a great example of this - it's really powerful in itself and especially when patch=programmed to do something more interesting - much more so than using it as the individual functions it is made up of - which can be had individually for a relatively small amount of cash!
I think I'm agreeing with you but using different words, then wondering what is the most efficient and basic ways to add those capabilities without introducing too much redundancy, does adding an EAS or Joranalogue compare 2 give me the additional logic and rectification to remove the contention on my existing modules? (although I've not actually used plog for rectification yet, so that might be a technique I should explore soon!)
That is one of the reasons I don't have Maths, I'd rather use 20hp to have multiple components I can stitch together differently, and sometimes independently of each other.
Disting and O&C are similar - you can only do 1 thing (or 2 with the ex/hemispheres) at a time...
Absolutely, that is why I'm looking at the quad quantiser to unlock the other O&C functions.
Disting I use as a quick fix to fill any gaps, and when its not being used for anything else I use it as a sound recorder
