Yes, I have seen your signature before while browsing, I think it makes a great deal of sense.
please check out the rearrangement of the rack.
a bit better:
links is a good buy - versatile - especially the middle section
kinks is discontinued - used or there's a clone version
the 2 2hp mixers next to each other are impractical - split them up? how are you intending to use them (I'd want 1 next to the MCOs)
do you really need the black sequencer and the pachinko - I've got both (well Marbles) but I've got a lot more
modules/ rack space - I wouldn't have both in this size case...
I'd probably replace the blinds with happy nerding 3mia & 3vca
I'd probably only have 2 or maybe 3 sound sources in this size case - you have 4/5 - 2MCOs, beehive, quarks, nRings & monsoon - but only 2 filters & some overlap with sound sources in terms of sound modification (clouds and nRings) - & no stereo sub mixing before hitting doupples
I'd probably want an FX Aid XL or 2 - versatile, useful effects modules with 1/2 decent ergonomics and
given that the black sequencer can do modulation as well as gates/triggers and pitch I'd probably look at dropping one of the stages at least in this size case!
so still imo not very balanced - as I said I'd add another row to this to house more 'support modules' which would probably get you into ball park of balanced system - at least with this number of voices
what do you value most in utilities?
what utilities do you feel are most essential/ least essential?
sequential switches, switched multiples, trigger combiners, matrix mixers, sub mixers, logic, attenuators, inverters (or combined as attenuverters), trigger/gate delays, sample and hold, mults etc etc... they're all good - it's how you use them that counts
I have more or less all of these (& more) sometimes in multiples
the more you have, the more you can copy, alter and combine more signals to create more interesting ones
thank you.
-- fretless19
NP
