Thanks for the in depth replies. I did get lured into the small cases. They’re so damn attractive until I try and jam everything in them. I’m aware of the VCA uses but didn’t realize that some modules have VCA’s but aren’t the same as freely patchable VCA’s. I think the Modemix was a mistake while I was shopping for a VCA. It appears to modulate the signal more than anything. I’m going to keep forging ahead and diversify my racking evolution.
Thanks gang!
-- Lowtide
If you go through the rest of this forum, you will see the #1 issue... by far... is people trying to build-out a tiny first case. They make things exponentially harder using a small case. As you learn modular and more importantly, what direction(s) you want to go in, you WILL add more modules and possibly even get rid of a few others. But more often than not, what you start with won't be enough. They don't call it Eurocrack for no reason.
Give yourself the opportunity to broaden your collection and freely add more modules. Empty space in a case is a GOOD thing. If you do decide to go with a small skiff set-up (for whatever reason), there are plenty of synth-heads looking to upgrade to a bigger case... because the case they originally bought... was WAY too small. :)
