Interesting to read that you had the same setup before moving on.
-- kvnlxm
I haven't moved on! I still have the DB-01 and Digitakt and use them, alone, with each other, and with my modular. The coupling can be as loose as sharing just clock, or I can send CV/MIDI information among them. But I have mostly not tried to do anything in the rack that I could reasonably approximate (or, in the case of the DB-01, exceed) outside it.
