Thank you for the detailed replies everyone.
I now believe I have a clear path of what I need to take my rack in the direction I want to go.
I think the next module I will go with is Veils after more research. The updated version is really neat!
Although the fx aid xl that Jim mentioned is very very tempting. I've instantly fallen in love with it after seeing a few demos. Is there that much of a difference between the fx aid xl versus the fx aid, aside from the extra CV to control the settings?
I'll be DIYing a few things too, like my case, the aim now is 12U/104HP that I'll slowly be filling over the next few years or so. Could also get away with a DIY stereo mixer, hopefully that's not too bad.
Thanks again!
-- unclepeter
No problem - good you found some use for our ramblings!
fx aid: xl is bigger - so better ergonomics (because the knobs have more space) as well as the added advantage of extra modulation inputs
for a DIY stereo mixer I'd consider the tesseract tex-mix - you can expand it with as many mono and stereo channels as you want (4 at a time) and the smd is already done for you so just panel furniture and headers to solder!
