Hello All,
I recently received the Behringer 2600 Blue Marvin and wanted to share with you my first impression on this Blue Marvin:
It starts with just the dry sound from the Blue Marvin, using only the 2600's reverb at about 20%. Then around 1:05 I start to screw up the sound more and more, while as from about 1:30 adding external effects (see below for details) and at about 2:45 the sound is totally screwed ;-) All done with the 2600. Then slowly afterwards trying to get back to the original sound (a bit after 4:00) though still with the external effects.
Other than a MIDI keyboard and the following external effects, only the B. 2600 Blue Marvin has been used to produce those sounds:
- Reverb by Source Audio - Ventris Dual Reverb (E-Hall reverb with Swell reverb)
- Delay by Electro-Harmonix - Grand Canyon (tape delay with stereo ping-pong effect)
- Leslie effect by Neo Instruments - Ventilator II
Thank you very much for listening and kind regards, Garfield.
