I would get the modules from the videos and then follow his patches one by one for his voices. He did a patch from scratch one time
-- greenfly
That's the plan! Only thing is I can't seem to find the Veils in stock anywhere, most are on pre-order until December at this stage :(
Will try find one second hand, but are there any alternative solutions for the interim?
Also little update on my progress: I've managed to buy the Plaits and PNW online and have found another store that stocks all the other modules in my original post (minus the Veils). Would the 4MS Listen 1/4 also be a good replacement for the Intellijel Outs? I do plan to use this with headphones mostly, but have a A&H ZED60-10FX mixer I can run it through to listen on my monitors too.
A friend of mine also has a 2HP mult and trim, along with a Kinks that I can borrow. Would this be enough to get me started for now, or is there another utility module (maybe from Lugia's build) that I can add which will keep me busy while learning?
Edit: Typo in mixer name.
