@garfieldmodular - thank you! Yes, that’s the René mk1 in the bottom row :)
@jb61264 - the Disting Ex is starting to be capable of too many things so I’m thinking of getting another one or maybe two more..at some point :)  But seriously, I’d want one for drums alone, another one for everything poly, and a third one for utilities.  One day :)
As for the new Poly Exciter algo., in this patch I used one of the built-in tables (sqr wave) as the base and patched the Alizon Devices APC Theremini’s audio out to input 5 on the Ex which I set in the algo’s menu to ‘external exciter’ - when the clean sound is getting distorted, the external exciting is happening. This is where the whole thing gets experimental and I like that a lot.  The other three mod inputs (I used the default settings like tone, pressure..) were fed with Rungler output signals from the Benjolin. Modding Poly Exciter, as far as I can hear, can get you to interesing territories.
In this patch the Ex’s L-R stereo outs were patched into the Mimeophon and the Erbe-Verb. Pitch CV and gate to the Ex were arriving from the OP-1, via MI Yarns. In order to be able to fully use the Poly Exciter, you need to copy the exciter table(s) to the SD card - one is available through the Expert Sleepers website, in case you haven’t yet gotten that. There’s a way to create exciter tables/folders but that’s too complicated for me so I work with what’a been available by Expert Sleepers.
Cheers,
Gabor
I am inspired by birth, death and the events inbetween.
