A rackmount case that doesn't require 4hp for power sounds interesting, do you have a link?
I have indeed studied the small racks suggested by Lugia. His feedback posts are a wonderful resource here and I discovered several of the modules in my proposed rack from his suggestions. I suspect I will be doing some iterative experiments with this, for example my idea of using the input attenuators on the VCAs as a mixer is something I'll have to try out to see if it meets my needs.
-- asleepwheel
Hi, I have the Nifty Case. I quite like it. 84hp with power, two channels of midi to CV, plus a clock and the case itself is quite nicely built. As everyone says, though, you will probably very soon wish you'd bought a bigger case - although I do quite like having a small case personally. It fits on my desk nicely. But I filled it with some not quite so small modules. Here are my choices:
