I've used a Quadratt as a cheap and dirty "AND". As long as the module you're feeding has a minimum voltage to trigger that input, you can feed two gates into the Quadratt and attenuate them so that each individual gate is under the threshold. But when both are present, you're over the threshold.
A little off topic but still relevant IMHO. But should work with any DC compatible mixer with attenuation.
