This should work: https://www.modulargrid.net/e/mutable-instruments-stages In this case, you can assign the time/level jacks as needed, and even break out the EG segments so that you can also use this as a sequencer. Not your basic ADSR, and it IS a tad spendy, but if you want that level of control, it doesn't get much better than this...even at $359.
