Hi Ronin1973,
Thanks a lot for your reply. As already mentioned in my previous post to you, I added the "Reverse power protection" parameter, you might have missed it :-)
Those voltage ranges for each output and/or input, is actually a good one. The part that disturbs me a bit here is that for this kind of information most manufacturers even don't bother to provide such information neither on their websites nor in their manuals. Yes, I know there are a few manufacturers who provide this information, then again not consequently over all their modules...
That makes it even more difficult for me to provide a consequent stream of "equal information" (as that's what it seems to me you are looking for, and I actually do look for that too) regarding that matter. I added the reverse power protection parameter since I do think that's indeed good to have that information quickly available, you got a good point there and thank you very much for that.
Regarding the voltage ranges for the jacks, yes it's a very valid and good point too however for the moment I do see a practical issue about that (since the manufacturers barely provide this information, i.e. as explained above) that I am not going to include that as part of the parameters in chapter 3 however the little good news for you is, for those modules where this information is provided, I usually add that in the flow diagram in paragraph 5.4. So what you could do for the time being till the manufacturers will provide more regularly this information, is to check out paragraph 5.4, if a module has been provided with this information then you can find it in the flow diagram.
Thanks a lot for your feedback, have a good weekend and kind regards, Garfield.
