Hi Plragde,
I had a look into the appendix/chapter numbering, yes it is possible within Word to do "Appendix numbering" instead of chapter numbering, I manage to get that work. That would be heading 1 (in style format section). Then Heading 2, i.e. for paragraph numbers, I managed to get that to work to, so I was quite happy at that level. Say Appendix A then paragraph would be A.1 however then the further levels, I got stuck at heading 3 level, there seems to be no way within Word (at least I couldn't figure it out, even not with googling it on the Internet) to make that work, Word forces you then to use the format 1.1.1 instead of A.1.1 :-( I need to keep the formatting accurate since chapter 7 (Appendix A) is in a way a copy of the paragraph numbers of the rest of the document, only a 7 has been put in front. So let's say in the report you want to check something about paragraph 3.8 - PCB details, then in chapter 7 that would be 7.3.8 - PCB details where you can find the entire explanation of paragraph 3.8.
But somehow if I switch over to Appendix only numbering, it doesn't work beyond heading level 2 :-(
And it doesn't help to switch on Legal style numbering as suggested by someone on the Internet.
So if you know how to get that work, please do let me know otherwise I am sorry to let you know that chapter 7 will stay as chapter 7 - Appendix A. It reminds me why I hate Word ;-)
Thank you very much for your feedback and kind regards, Garfield.
