thanks!
if you can find a kinks buy it - inexpensive and incredibly useful - I always recommend this, links, shades and veils as a great utility starter set - pity kinks is discontinued!
doepfer matrix mixer - a thousand uses and again inexpensive
doepfer sequential switch
basically all the doepfer utility modules - excellent value for money - helps if you have a deepish case!
