toodee
The idea was to provide a "standard" instrument arrangement (e.g. bass, drums, lead, arp) in a single system, while still allowing for some wierd-sound exploration. And that's really my goal with modular - sound exploration in a non-DAW environment.
-- jtunes_ia
Hello and welcome to MG !
While that sounds like an epic goal (hell, I had the same when I started), I want to offer my personal experience on the matter. Bear in mind, it's only that, advice coming from my personal experience :-)
The fact is that modular is very expensive so as Lower Rhythm very well puts it, you want the use of your hard earned money to be maximized and for the type of electronic music you refer to, any drum machine will maximize $$$ way better than any drum module. I tried - and sorta failed - to go down the road of complete groovebox when I started my journey, and eventually bought back a small MPC for the drum duties because I realized that what I was doing with drum modules was a subset of what I can do with an MPC/Digitakt/Deluge (I had extensive prior experience with that sort of groovebox device before), and that if I wanted to justify having modular drums, it would 1. require a lot more supporting modules (modulation sources, submixers, etc) which cost $$$ and 2. perhaps more importantly, require a lot of attention/time to actually handle the complexity of modular drums.
If you buy a 2nd hand drum machine, you can test drive that setup for at least a few months and not loose any cash if you decide to resell the drum machine. Same goes for most 2nd hand modules BTW, what a nice way to try things out (but the selling/buying can take some time and patience). You can then plan a very small modular setup to start getting your hands dirty (but please consider VCV first, a lot of learning there if you're ok with using computers for music), if you're inventive you could most likely use it to synthetize most of your synth sounds and even produce drum-ish sounds for your sample-based drum machine. I can almost guarantee that Digitakt/MPC+ a small well-thought-of 104HP modular can get you pretty far already, and most importantly as Wishbone Brewery said it, it will be fun for a long while.
Hope this helps ;)
D.
