should do - as long as it is an analog clock divider, which I think the doepfer is
I often use a dreadbox div to do the same thing - although usually I use a square wave from the oscillator too - og tides high/low outputs as the input to the divider
/2 = - 1 octave
/4 = - 2 octaves
