Actually, Ableton is probably your best bet here. Not only does it deal well with really insane production demands, Ableton also has CV Tools...its own built-in version of Volta/Silent Way. So if you've got the right interface module, it's a snap to send your CV/gate/trig/clock out one side and the modular audio back on the other.
However, while typing this up, I had one of those flashes...and checked the VCV Library pages. Sure enough, VCV now either has, or has paid access to, modules that will allow you to build up a DAW to your own specs. Definitely more fiddly than Ableton, but if you're willing to put the work in to build up a "DAW template" of a sort, this would ALSO be a viable possibility and could be made to be even more of a bespoke solution.
