the-erc
Here's my own attempt. Many ideas stolen from @troux.
Mixing solution :
  • SSF Vortices is the main mixer, which is stereo. the main outs go into the MSCL (bus compressor) and then the Isolater for output.
  • The four non-kick voices (BIA, Entity, Hats, Disting) get high passed by the Shakmat Hi-Pass and then multed into the Vortices' mono inputs, and also the two 2hp mixers (which are effects sends).
  • The white 2hp mix goes to FX Aid for delay/reverb/etc and comes back to a stereo in on Vortices
  • The black 2hp mix goes to the Kith Ruina for distortion and comes back via one of the stereo ins on Vortices (as mono). Not sure about this... maybe not filthy enough.
  • The Kickall goes into the remaining stereo in of Vortices, (again as mono).
It's a bit perverse to use the stereo inputs for the things which I want dead centre but it makes sense.
Non-mixing additions :
  • extra power!
  • more passive switches
  • I dropped the Takaab SMIX to make space.
I have tried to think about the cable routing, but there's only so much you can do with so much packed into such a small space. And of course I have no EQ anywhere which is not ideal. I was also considering a build around the Befaco Hexmix but, being that bit bigger, it makes doing anything sensible with the effects quite difficult.
