Basic thoughts on it:
– Already own the case, Hi-HatD, Clap, SY-05, Pam, a Novation Peak and an Erica Bassline DB01
– Create drums with Maths, BlackVCO, Quartet, + add some punch by LedRover
– Record or enrich with own samples using Sample Drum
– I will do muting/unmuting on the tracks through the sequencer for now
– EQ will be done in the DAW. Alternative on my external mixer replacing the ES-8 with an Erica Link.
– The overseer works as a kind of DJ mixer for transitions, might be replaced with FX when mixing externally
– I want to have a Lapsus OS to manually control to open, close CV Aux (FX Aid) of the WMD Mixer which has very tiny knobs.
Do you have better ideas to replace the Drum Sequencer as it uses a lot of space?
Is anything missing? Should I ditch another voice and add more utilities?
I tried to replace the WMD Mixer but it is very hard to build finding an alternative for AUX chain with CV control on it.
