If I may applaud from the cheap seats, as someone still working my way through the newbie stage, Jim and Lugia's wisdom is mighty welcome. That priority/ratio model is a helpful guide.
It's good to feel appreciated - thanks!!!
I quickly discovered that the Synthesis Technology E370 needs a veritable army of modulation signals to live up to its full potential). I can't claim any intelligent foresight for this, but as a pleasant change, my ill-guided bumbling through life worked out rather nicely in this instance.
-- oldandintheway
there are a lot of modules out there (mostly shiny expensive ones) that really need a lot of modulation to get them to work best - often needing attenuation on the way in (clouds is a good example)
I don't think any of us can claim any form of intelligent foresight - it's just what we've picked up along the way - often from making those mistakes ourselves in the process
start with too small case - check
not enough modulation - check
not enough utilities - check
4, maybe 5 years later - experience in how to build modular synths that are worthwhile and usable - in my case both audio and video - and pretty much any size
