Lugia, Sacguy71, how many channels are you needing to handle for recording / mixing?
Maybe I'm missing something, but I'm surprised to see a discussion of large-format desks. My understanding was these are really only called for in large / professional studios.
I took some good mix & mastering certificate training recently. Everybody involved (myself, the teacher-engineer, and the other students) were all basically using "hybrid" (digital + analogue) rigs consisting of: DAW of choice, interface of choice, select external hardware (incl. analog summing for me) and select control surfaces. RE control surfaces, for me a Softube Console1 and Faderport1 work great: good build quality and hands on control, great DAW integration, enough channels (especially by setting up with stem or group mixing).
So I'm surprised you would opt for a big console vs. a hybrid setup. Am I totally not understanding your intended use case(s)? Do you want / need a ton of analog mix channels?
That said, IF I saw a desk like Lugia found, with big functionality, pedigree and in great condition, and IF I had the space for it and wasn't concerned about the huge weight (which I am), then I would be tempted to get one!
Thought I'd ask about your mixing use cases and suggest a "hybrid" mix setup for those with smaller space / budget etc.
