exactly - worst case scenario is you need some utilities to get everything to play nicely together - you could even use a couple of mults or stackcables and do both!!!
I've not seen many nonlinearcircuits modules around - I built a triple sloths which i use a lot - a nice easy smd build iirc - did you build it or buy it?
