HI All and Lugia :)
Quick update on the build
So far the build looks like this and as per Lugia's suggestions I have added the temps utils. To keep the costs down I have gone for the Michigan Synth works version instead of the After Later Audio version. I have also bought Maths instead of the Quadrax + expander simply to keep costs down and the Es-8 is in the case now as well. It's been an expensive month.
Unfortunately the cre8audio models didn't play well with the tip top bus boards and both burnt out as soon as I plugged them in correctly I might add. According to Cre8Audio, they agreed I inserted the modules correctly and have suggested the following reasons for why their modules malfunctioned:
1) the power inverter on that buss board is constantly putting out more than +5V on the +5V rail.
2) there was a momentary power surge of greater than +5V on the +5V rail of that buss board.
3) something momentarily caused a short across the power rails, which could be something like a patch cable falling across the pins inside the case.
4) a static electricity event (possible but less likely)
I don't know enough about Eurorack to comment otherwise, but the documentation from tip top states the following which is the behaviour I see in my case with all three LED lights :
The Zeus Studio Bus includes a built-in time delay to allow
the power regulators to stabilize before they start providing power to your modules. When the Zeus board gets powered up the +5V will turn first, the +12V and -12V might take up to 0.5 second to light, this is normal.
Also the documentation notes that:
The Zeus Studio Bus is a powered bus board, as such, it takes only the necessary amount of current needed to power the modules connected to it and not more than that.
In any case, that's my experience of Cre8audio and I was anticipating at some point to have to deal with fried modules from what I've read on forums. I probably won't be buying anything from cre8audio again as its too much of a coincidence that 2 modules from the same manufacturer burned out ( I plugged them in separately on different occasions), whilst I've had rock solid behaviour from other modules and manufacturers. Suggesting that I may have dropped patch cables on my bus board was a bit of a low blow by them as well in my opinion.
Their response has got me doubting the tip top 5v rails though now as I don't know how to check that and when I asked Cre8audio, they didn't want to tell me. Is there a way I can learn how to do that as I want to learn this sort of stuff myself? Is it a complex or hard process to use a multimeter?
Would removing all modules that use the 5v rail from my system mean that my modules wouldn't be affected by any funny business on the 5v rail? Apologies if that sounds obvious and too noobie.
I assume this means that I take out the BIA which I was planning to do for the drum rack skiff in any case.
