no
cables and jack sockets generally work with signal and ground
you'll send the hot signal to ground and the ground signal to where you are wanting the actual signal - which may or may not cause damage to your modules - you are free to try it at your own convenience!
if you want to reverse polarity use an inverter or polarizer module - this will take the signal and reverse the polarity
