I have included Pamela and Ornament and Crime for Sequencing, quantized note generation and other functionality (Hemisphere firmware on the O&C)
-- benjaminjamesgreen
Glaring omission : switches. Pam's and OC gives you 12 channels of clocked triggers and modulation -- that's great (although possibly not enough considering you have five voices in here). But now you want the kick drum to go to half-time for a while. How do you this? From the look of your rack you have to go menu diving into Pam or OC, or start repatching while you're playing. Not a good look either way.
If you make copious use of AB-switches, switched multiples, switched OR-combiners etc etc you can redirect and recombine your control signals around the rack. I guess from the phrase "Minimum Viable Party" you know mylarmelodies on YouTube: check out his video on switched multiples; he covers about half the reasons you will want these.
I suggest you would also want at least one envelope generator (for MCO's amp envelope), and probably a second for the filter. Yes you can generate envelopes from Pam but again, you are going to want to tweak them while playing so having actual knobs to turn will help a lot. For reasons of tweakability and control you will also want some attenuverters/offsets and maybe a CV mixer.
Latest stuff : https://soundcloud.com/user-352590333
