Hi everyone! I decide for a while to build my first modular synth, I have read many posts and articles about first racks and how you can do it but I still have a lot of doubts (and error on the draft setup).
The idea of the setup is quite simple. For the rhytm part I use the Rytm mk1 while I would like to sequence the modular synth with the Digitone (which I will replace with octatrack mk1 or 2 when I can) and also use it for Fx (reverb, delay chorus).
Here it is the draft about eurorack ( https://cdn.modulargrid.net/img/racks/modulargrid_1424957.jpg ), I think its a good idea to start with a very simple system. If the kind of music can help you I'm focussing on raw and loopy techno.
I put the Doepfer A-138pV cause I like the idea to live control (also with On/off switch) the various layers but maybe 4 channels is too much.
Also I don't know if the midi to cv from Doepfer can fit with this setup or if there are better solutions, same for the output module.
In this way, however, I would have only two layers where I can mix and master for the track, one from digitone (with digitone and modular sounds) and the rytm session. Could it work?
I know there is a bit of confusion but I tried to explain the situation as well as possible, any advice / suggestion / teaching is welcome.
This is my first approach to the world of modular synthesis and I would like to detach myself from the PC as much as possible (using it only for some sequencer or only for mix and master the final track would be an excellent result).
Thanks everyone for your time!
p.s. as case if think that this one could be a great solution, Doepfer A-100LC6v Low Cost Case VE (thomann)
