Happy new year everyone! And thanks for the the kind words; glad you enjoyed the music.
@troux - I'm very inspired by MylarMelodies approach. I think the key is to have lots of small pieces which can be combined in different ways.
@sacguy71 : the short description of the recording is that everything goes into a mixer and the stereo out from the mixer goes into the DAW. Afterwards, in Logic, I make it a bit louder but nothing fancy : whatever compressor preset sounds good, then a peak limiter. (Actually I make it a lot louder : the raw recording still has > 10dB of headroom)
The long description of the recording is : I have three audio lines out of the modular (Kick, Synth, Hats) which go into the mixer, as does the keyboard. On mixer sends I have delay, reverb and the Filterbank, each coming back into the mixer on its own channel. The kick gets its bass EQ'd up a bit, and everything else gets a dramatic reduction in the bass band. Kick and hats go to the main mix; everything goes to a bus for some gentle side-chain compression key from the kick. (You can hear this quite clearly on the pads near the start.) That sub-mix rejoins the main mix. While playing I adjust the levels of the delay and the Filterbank, but otherwise don't touch the mixer.
The main sequencer is the Beatstep Pro, although some sequences are generated by Pamela's New Workout.  I use an OR Combiner
to direct trigger/gate sequences from various sources to the open hat and the Entity.  Triggers for the closed hat and the kick come straight from the BSP.  Additional triggers from BSP go to Pique, which is set up as two AR envelopes wiggling parameters of the Entity.  The two pitch channels of the BSP go into the switched multiple so they can easily be directed to different places.  One velocity channel from the BSP modulates the cut off of Font.  Some manual wiggling from the Tetrapad.  This probably makes more sense if you look at the rack :)
I feel like I'm only scratching the surface of what this rig can do. I didn't use Disting at all. I didn't use the Doepfer LPG at all. I used a grand total of 4 melodic sequences on the BSP and only 4 drum lines. All the modules keep doing the same job throughout the track, especially the BIA is very under-utilised. The only thing I feel that I might need to take this further is more switches!
Latest stuff : https://soundcloud.com/user-352590333
