a quad vca, such as veils, in first batch of modules is a great idea
output modules are not always needed - it really depends on what you are plugging into
unless you absolutely need balanced, then you may need nothing other than adapter cables and/or attenuators, which are useful anyway
veils will work fine as a mono unbalanced output for example
