Is there a quick or easy way to check on the Argon8 itself to check the firmware version?
Kind regards, Garfield.
-- GarfieldModular
Yep...get into the Settings menu, then go to Settings-General, and you'll find the firmware indication.
And yes, DO read the V.2 manual first! https://www.modalelectronics.com/wp-content/uploads/2020/05/argon8_MANUAL_v2.pdf (there should be underscores before and after MANUAL, fyi...but the forum had other ideas). This has a lot of updates from the V.1 firmware, and there's some interesting things there. The synth LOOKS really basic...but the fact is, there's some major horsepower under the hood on this thing, and it's pretty easy to access. And one of the biggest 2.0 changes was the addition of MPE capability...so if you have an MPE controller on hand, this effectively kicks one of the Hydrasynth's bigger draws to the curb. No ribbon still...but hey, that'll just take a little more ingenuity to work around...for now.
