If you make the rack public then other users can viez it properly and get click through and infomatics - really useful when helping!!!
You need more vcas - get a quad cascading vca - mutable veils or intellijel for example - I'd also consider replacing the tallin with the intellijel 1u vca - all of these are dc coupled - as are most vcas
How are you mixing? if you do not already have an external mixer - you either need to buy one or put one in the rack - even if you do have an external mixer you will need sub-mixers, panning, modulation
Some utility modules will massively add to the variety of patches that you can create - mutable links, kinks and shades for example
you will need to free some space to accommodate these modules - the erbe-verb seems to be the obvious sacrifice - too big, not really a generic end of chain reverb (which is possibly what you are after) - replace this with an FX Aid XL and it will free 14hp more up - this may still not be enough!!! next to go would be the mimeophon (you seem married to the erica stuff) and again replace with an FX Aid XL
