I'd want modulation and utilities - you may not think you want them now - but you probably will find you need them down the line - maybe go and do some research! this is where modular shines in my opinion
On top of that I would look at the size of the case and abandon it if you have not already bought it - get a bigger one - TipTop Mantis is generally best bang for buck, but the large behringer may change that when it appears - if portability is a factor, then the mantis is probably better - the new case looks significantly better than the original
However, saying that, what you have already selected looks like it would generate some harsh noise, to me
