I'll second that last bit from Ronin: split out your sequencing and control (and performance mixer...which you don't have YET) to open space for the stuff you missed. The present build has some good toys in it, but it's missing the "basics" that will allow them to really cut loose. Also, yeah, the module ordering/layout is really a mess; try grouping your functions together...generators, modifiers, modulators, controllers...and that will make for a more cohesive result, much easier to navigate.
BTW, this tale is a really good example of why I tell people to avoid the majority of synth videos on YouTube...at least, as a source of authoritative info. Remember: a lot of those are nothing more than commercials and the person waving the module at you and screeching about how AWESOME and INDISPENSABLE and [insert imperative adjective here] it is...well, they probably got the one they're waving around as an "accommodation", hence the added enthusiasm. But those things are designed to suck you in just as effectively as anything you'd see on TV for detergent or cars or deodorant or soda or or or...
