That's better, but the same comment applies. Once you're putting four 2hp mix modules in your system, you should probably consider a single, more robust mixer module instead. Also, all of those 2hp modules so close together will be fairly difficult, if not impossible, to manipulate, especially during live performance.
You don't need two plaits, two tides, two rings. Keep one of each and fill that space with a greater variety of modules!
