One of the things that appealed about mixing in the case was that I could sling it in a bag and take it to a jam session without having to pack a bunch of extra devices and PSUs.
Do you think it would be better to consider a couple of smaller mixers?
I couldn’t find a combo that gave me the ability to have sends per channel and mix in stereo FX returns. Also the cue facility on the performance mixer is pretty handy.
The inclusion of the Polyend Preset was more for allowing me to play different combos of CV settings from the pads e.g increase the FX return volume and use the high pass setting on the Disting DJ filter to create builds and drops etc.
The Preset seems to allow you to set the CV values per pad snapshot so may not need a VCA for scaling.
Can you suggest a compact sequencer that could be used to drive the Bassline? I wondered if the Varigate 4+ might work...
It occurred to me that although the Bitbox provides a lot of voices I would be sacrificing some hands on control and I wondered whether it would be better replaced with a Sample Drum and Erica Kick module.
