try posting an actual link to the rack not just a picture of it - amazingly there are thousands of modules and nobody knows all of them
you have made mistakes 1 and 2 in modular newbieness
filling the case up too quickly - with no room to expand
getting all shiny trendy modules and forgetting about the plumbing
You have way too many voices and appear to be quite light on utilities for so many modulation and audio sources and destinations
veils and blinds together in such as small case is too much as I think are 2 tides (even if they are different models)
possibly a good exercise is to explain (here or to yourself) your reasoning behind picking each module and question why you haven't selected more basic utility modules
I would reduce* the number of 'voice' modules (voices/vcos) to 1 or 2, keep one effect, rene/tempi, veils and one modulation source and work out how these combine (probably with additional utility modules) to produce interesting audio - you may want to strongly consider getting a disting mk4 as well - it will help you understand what different types of module do and guide you on your path
*this may just involve sticking them in the cupboard for now and reintroducing them when you are actually ready for them
