Your welcome. Also, I forgot to mention. The noise module from Intellijel also has a slew limiter that can be accessed independently.
The Morgasmatron is also capable of self oscillating. Pair it with a VCA (Shakmat and Intellijel are BOTH coming out with 1U VCAs) and some envelopes from the O_C and you can generate some decent kick drums. Filter some pink or white noise through the other filter and you have snares and hi-hats.
By modulating the Morgasmatron's mix knob at audio rates you can get a ring modulation kind of effect.
The Shuttle is tasty. But I strongly feel having the O_C for some onboard sequencing that can also be clocked and reset by the Shuttle will give you lots of additional modulation possibilities.
All of these modules should stay very useful should you want to expand or expand in a different direction.
