It's hard to give advice as to what to get as an essential module. That's going to depend mostly on what you want to do with your set-up.
But let's look at the Minibrute.  It has a sequencer, envelopes, filters, oscillators.  However, it's lacking in effects.  Effects aren't as sexy as an uber-VCO.  But they are the most underrated part of synth sound design.   The Koma Field Kit FX would be the first thing I look at.  I don't own one.  But if I had a MiniBrute, it's looks like a great pairing for under 300Euros.
https://koma-elektronik.com/?product=field-kit-fx-modular-multi-effects-processor
It's a standalone box and won't eat into your Eurorack case. Plus you'll get use out of it beyond your basic set-up. You can still add other effects like a Clouds, dedicated reverb, high-end delays, etc. to your actual case and they will all integrate together.
The next modules I would purchase would be some multi-function modules.  Think of them as a tasting flight for dedicated modules.  The Ornaments & Crime and Temps Utile are my two favorites.  Between the two, you get a TON of useful features for additional sequencing, envelopes, quantizing, Euclidean patterns, clock multiplying/dividing, LFOs, etc.  You can also add an Expert Sleepers Disting for under 200Euros.  The Disting has a lot of features but can be maddening to work with the interface.
 The O&C, T_U, and Disting sum up to 18 Eurorack spaces... so they are going to fit into almost any starter system.
Maths or the Befaco Rampage are great. At a minimum they bother offer two slew limiters. But they both can do so much more. However either module takes up quite a bit of HP for their functionality.
I own Ornaments & Crime, Temps Utile, Maths, a clone of Clouds (the Monsoon), and the Disting just for reference.
