Thank you for your recomendation ..much apreciated.
- Main reason I want to put those on a case is so I can carry them to a friends studio for jamming...They do take a lot of rack space but they give a lot too.. I want them to be properly packed if I am going to move them around. As for the rear outputs/inputs I can just move them to the side of the rack, just will need some sort cables and DIY work. Both synths also offer audio out on the patch bay. It is also true that I do not need to build the case right now, I have first to get to know them well at home.
- Well, regarding modules math comes always a one of the most recomended modules, I think is quite complex but can do lots of thing. For example turning the DFAM into a Subharmonicon .
 In fact I already bought one secondhand (ups!!), a never used mk2 still under warranty for 220€, I could not say no. ;-) It can wait in the drawer a couple of months if necessary, first I ´ll get to know both the Neutron and DFAM.- The disting comes also recommended but after your feedback I think I will just pass. Main reason to go modular is to have full hands on with no menus, Disting does look like a pain in the ass. The other modules have not been thought thoroughly though.
- I still do not have the CV.ocd with me but I guess will serve me to route some modulation/trigers from reaktor blocks to the modular. I do not think I will need the Gate/boost as as far as I know all trigger/gates do respond to 5v. Also one of the neutrons midi cc´s can be assignt to a cv out, there is also a midi gate cv out present.
- As I said before I also own a Bastle Kastle, I saw ST modular sell a DIY eurorack version of it, I may try to convert mine.
 http://www.st-modular.com/eurokastle.htm
- Thank you for your list of recommended modules, I will look into them. Still my budget for hardware is 2000€, which I will spend sooner or later (rather do that on hardware than partying.. money burns in my pocket :-)). So far DFAM 520€ new B-stock, Neutron 275 new B-stock, CV.ocd 130€ Maths mk2 220€ second hand under warranty. That makes 1145€ so far...
- If I make my own case I think I can do a nice one for less than 200/300€, flight case like; I think I would go for a meanwell RT65B PSU and a single busboard. There would be no much difference in price in making this or a small 3U 40HP case. The RT65B delivers up to 2.4A on +12 and up to 1A in -12 if not under full load, also has +5V altough I do not think I will need it. - Neutron is quite power hungry, according to Behringer 1A but I red somewhere is more like 700mAh. 1.5A might be enough for the whole thing but I preffer not to force the PSU. It will need to feed around 4 to 6 modules, maximum. - Other recommendations regarding PSU/Busboard combo will be apreciated too; 200€ tops
- If I add the ST Modular Kastle to the set up it would mean going for a 6U 90HP case, I would have 10 HP empty space to add something in the future ( out of the modules you recommend one could fit, as there is even an 8hp version of temps, uTemps).
Regards
Javier
