This patch attempts to create the appearance of a wide range of voices from just one voice, by modulating waveform/timbre and how often it's sent to the delay. A second voice is occasionally brought in tuned to a perfect 5th of the primary voice.
Before getting started, tune the top oscillator to a C, and the bottom to a G.
The Rene's X channel is used to sequence the frequency of both oscillators. The X channel gate triggers the envelope for the primary voice, going to the dry channel. Use a slower Tempi clock to The Y channel or a more sparse gate pattenrn to trigger a second envelope which controls when the oscillators get sent to the Mimeophon. The Y channel CV also modulates the waveform from sine to saw on the oscillator. C channel CV gets mixed with the Y channel's envelope, using Maths sum output, to modulate how much of the second oscillator (perfect 5th) gets sent to the mimeophon.
For best results, keep Mimeophon clock to same tempo as X-channel, and Rate at noon.
Play with:
- envelopes
- clock speeds to the Rene
- gate patterns on X and Y channels
- CV on Y and C channels
- Mimeophone Zone, Repeats, and Halo
